Root [Virgin Mobile] [ROM][CONVERT] Beanstalk 4.4.2 (2/26/2014 Build)
The stock app won't work for mms. I use Hangouts and i think some of the 3rd party apps will work but honestly not sure which.
Hangouts isn't bad, but I use and recommend EvolveSMS, it is a great third party alternative. Lots of options and a very responsive dev.
I'll try it. Want something other than Hangouts, just haven't had time to mess with finding one that works.
Edit.. What settings are you using for mms? When I get an mms i get notification but nothing shows up. Seems to send ok, just not recieve.
My phone just lost over 40% while the screen was off and in my coat. uploadfromtaptalk1393443618228.jpguploadfromtaptalk1393443632846.jpg
Your other option is to download the d2lte version instead of the d2spr version. Seems like Virgin Mobile users, thanks to the APN fixes provided by @MopedRyder, are having either few or no issues with LTE the way the Sprint users are. I am still removing the device checks from the asserts, but I know a lot of users have confirmed this as not being necessary if using the latest Philz.
Alright I'll give it a try. Thanks.
Currently stuck with the Carbon logo spinning waiting for first boot. Don't think it's happening.
1. Flashed latest LTE nightly
2. Gapps
3. DKP kernel
4. Optimized Dalvik
5. APN fix
optimized dalivic and bionic don't seem to play nice, or setting up the ART runtime, skipping them seem to hold the best results
Updated with 2/26 version. I did a dirty flash. So far so good. Even though I replaced the eri.xml my carrier says "Sprint".
Still works great.
I love this rom running it since mopedryder posted it. Only one thing I been trying to figure out is when I call my phone it doesn't go to my voice mail just get a bunch of clicking not Abel to leave a voice message
