Tokens210
Android Expert
unless you have windows 8.1 or don't have WinRAR it doesn't work on my laptop no matter what, ive been modifying the asserts through es file explorer and it works miracles
Windows 8.1 shouldn't matter, most likely in order to pull apart or play with Roms or apps or even themes you would need the java developer runtime and to link it into windows environment just like you'd need to do on windows 7, Linux is actually the best for playing with phone stuff as most of it accepts Linux code by default or sometimes will be written in it
As for the winrar, that's on you if you'd like to get it or not, although I'm pretty sure the free version is still no time limit just limited abilities
Also when using winrar to modify anything the key is Never let the file unzip, cause the file technically was never zipped in the first place, it was signed and the program which signs the zips or apk happens to spit out flashable zips usually so if you unzip it, rezipping it technically does nothing cause its no longer signed
