TheBritton
Resident Galaxy Cat
Hope you are all filled with pure gratitude. Whatever you face, whoever you are. There is so much that is good. Merry Christmas!
Hello!
I wiped system, cache, dalvik. Then I flashed the Deodexed rom, wifi fix, SuperSU, and KNOX app remover.
On its first reboot, it worked great, started up and made it to the Wi-Fi scanning page in the first boot. However it then froze and then restarted.
But this time its just stuck at the Samsung GALAXY SIII splash screen. Any ideas what could be wrong?
Using Philz 6 I believe
More troubles:
So now every time I hit "wipe data/factory reset" it just resets.
Even more bad news:
My god what is going on. It just randomly resets whenever it's flashing or doing any sort of operation.
I have not heard of the issues you are having. Did you verify the md5 before flashing? Try downloading the rom again, this time with your pc, and using Philz, wipe everything, data, cache, dalvik, and try again. Once the rom boots, let it settle a bit. But there seems to be something conflicting with the system. Did you restore any apps or system data using titanium backup or any other backup program? Good luck!
Thanks for getting back to me!
Thankfully, my phone is working well now. I couldn't get it to really do anything because every attempt at wiping /data would cause it to restart. Eventually manually cleaned out everything I could and then installed ebildude123's 4.4.2 CM11. That also stayed on the Galaxy S3 splash screen but eventually actually worked.
Regardless, thank you!
if you have knox dont flash anything that is not a mk5 4.3 Rom only if you flash a kernel it could soft brick to return to stock use kies 3 to restore or try the md5 stock recovery file i posted.
but wait till jd or other weigh in.
Ok, mr. The Britton, I had a question about the CONTENT I WAS FLASHING, NOT ABOUT HOW IT WORKS! I understand you can flash older versions of android and not brick because it doesn't modify knox, therefore, in thory knox doesnt care and take no precuations or BRICK. But I already know this and you answered to this already. My inquiry was if, pacaged in this zip, was something was truss to modify knox, which will trip the knox flag and ultimately brick ny device, this was because this rom said that it doesn't come with knox and all the apps, associated with it, which made me concern over, if this didn't have knox in it, then it would try to modify it because it doesn't have knox supported, and my other conceived ideas that would make me think that flashing this rom a bad idea. It seems people. are thinking that others on this forum are less intelligent. I mean there are more step by step instructions than there is information, this is something that wasn't in the victory forums, I can't help but obsurve this, but part of this is probably because this phone is owned by so many people and trends to more audiences, but that is just a theory, because why would so many people try to root if they don't understand what it is in the first place, but that's just my opinion.
I really need to install this as soon as I get a fully working laptop, this rooted sprint rom that my phone is driving me insane since it has no MMS and still nags me to update. I'm completely new to flashing but I want to learn to if it kills me. I hope you get a rooted build out soon.
Hey, your back.
First things first... relax... OK?
DO NOT worry about Sprint vs. Virgin, that really isn't very important and your situation isn't really that bad... not bad at all.
If you start a NEW THREAD/TOPIC, I'll try to walk you through what you need to do. I am fairly sure we can get you onto jd's stock 4.3 using just the phone.
Doing things without a PC is sort of my specialty... Start a thread and I'll reply. Just say "help" in the body if you want... We'll edit it later.
Hey!
I have a quick question. A few hours ago I had 4.1.2 with Virgin mobile & I tried upgrading to 4.3 because I would get that new update pop up every hours or so and I tried upgrading but it wouldn't let me, I'm guessing cause I was rooted and it only allows unrooted phones. So I went on the search for a unroot for the 4.1.2 and couldn't find one until I came across to "Update Sprint Galaxy S3 SPH-L710 to Official 4.3 L710VPUCMK3 (Odin and OTA Stock Method)" and I used it. As it updated to that I noticed that I got switched to Sprint and it wasn't Virgin any more. Everything works excepts the Data (4G) & I was wondering if there's a way to get everything back, since I didn't backup any files. I know that was stupid since I'm new to all this rooting and etc... I'm asking for any type of help, thanks.
Hey!
I have a quick question. A few hours ago I had 4.1.2 with Virgin mobile & I tried upgrading to 4.3 because I would get that new update pop up every hours or so and I tried upgrading but it wouldn't let me, I'm guessing cause I was rooted and it only allows unrooted phones. So I went on the search for a unroot for the 4.1.2 and couldn't find one until I came across to "Update Sprint Galaxy S3 SPH-L710 to Official 4.3 L710VPUCMK3 (Odin and OTA Stock Method)" and I used it. As it updated to that I noticed that I got switched to Sprint and it wasn't Virgin any more. Everything works excepts the Data (4G) & I was wondering if there's a way to get everything back, since I didn't backup any files. I know that was stupid since I'm new to all this rooting and etc... I was wondering if this would help me. Can anyone please help me. Thanks!
Can anyone port over the new wicked sensations touchwiz rom to virgin mobile no matter what I try to do the rom always stop working right or doesn't work right from the beginning ?!?
I put my last post on your thread because I thought you'd be the best man for possibly giving it a shot !! An most likely to get it working properly !!
I appreciate the vote of confidence bro. I'm swamped with working on my MBA at the moment, but if I get some time, I'll take a stab at it
