Bulldogz1097
I accidentally flashed a sprint rom and now it is stuck at the boot up screen. My phone has the ability to go to recovery and download mode though. any ideas?
yes factory reset or wipe cache system data and flash the 4.3 stock rom here: http://androidforums.com/virgin-mob...exed-deodexed-virgin-mobile-boost-mobile.html
s3 is confusing I'm pretty sure its sd card is internat extsdcard is external.I'm going to sound dumb when I say this...but if I want to mount an sdcard that mean I need a micro sd card correct? or is this internal memory?
When you go to mount, is it allowing you to access the internal/external cards in your pc?
Or even do you have a card reader in your pc?
You also need the drivers installed on your PC. Once you mount sdcard, the partition of your internal memory should show up on your PC as a removable drive. You can drag and drop a good ROM on from there.
Of course, the easiest thing would be to restore a nandroid.
how do I make a nandroid?
