Root [Virgin Mobile] screen mirror allsharecast 4.3
lordmage
with the new 4.3 update has anyone tested this,,, i have read conflicting information about it.
what i know before the update my dvd player and phone connected and worked just fine. now it is borked even when i did a test revert thanks to not having knox :D at this point i can only assertain from trail and error
you need to either be full stock unrooted with no flags tripped for the featuure to work or my phone hates me.
currently under 4.3 or mg2 it connects then turns its self off before any mirroring is done ala some last security check or something.
so what i would like to compile is a list of working roms and kernel combos for the virgin edition that would have this working.
i have confirmed that your status must be Official and un-rooted at this point. i am officially knoxed up and unrooted and it works. that was the only change.
Does it also matter if the Knox flag is set or not?
i have not tested that at least for another few months when the hardware warranty expires.
if your flag is set then you would be custom unless you kies restored i think.
they way i ended up fixing mine was using the mg2 reset zip which works for e and not advised for others. which took me to stock official 0 counts then i kies updated to knox 4.3. allshare worked flawlessly after connecting to wifi.
i tried all ways of none 4.3 knox and it failed even official mg2 failed for me. but once i went full 4.3 knox it worked like a charm like day one.
