Should be something here pretty soon devs are trying to roll out a kitkat experience just takes time every thing is built from sourceAnything new about the f3 device tree
I can't really say since this isn't my main phone and it's always plugged into the PC.Just wondering does the battery life get better with the a rom or is it really a crappy battery or both because im stock rooted and i either need a new battery or a new os
I really don't think there's going to be battery drain I have a battery saver on mine ROM last a bout two days but always in use to like a day of full use and as far as bloating u can use mini gapps that helps toobplus I keep GPS off I have very limited Google appsIt is better with the AdvancedStock ROM, as a lot of the unnecessary bloat is kept out. I'm assuming that's the ROM you're referring to. You'd have to try it out for a few days to see if there's any difference. If you're constantly using and recharging more than 2 or 3 times a day, then it's most likely the battery.
Well KitKat should come out soon don't wana reveal info I will leave that up too phenomenon too do soI use greenify + donation package (but no xposed) on my phone, as I have a lot of apps I like to use on the F3. I'm not constantly on my phone... use around 25-60% during a typical 16 hour day. (The 60% end includes gaming and streaming video via chromecast.) I top up, but not more than twice a day (aside from bedtime charging). If I didn't have greenify, I'd probably go through 70% or more. I also have the built in power saver turned on, to kick in at 20%.
Anyway... any devs working on this phone have any idea as to when KitKat is coming to this phone? I've noticed some phones out there lately that have similar specs to this phone running KK.
Well it was ready but an issue has come up with radio causing massive battery drain. Looking for a fix. Then I forgot about GPS so I'll have to get that working too. I do have a build uploaded to my basket build profile if you guys want to try it out but it has the issues mentioned above. If the issues are fixed then it's enough for an alpha.It is better with the AdvancedStock ROM, as a lot of the unnecessary bloat is kept out. I'm assuming that's the ROM you're referring to. You'd have to try it out for a few days to see if there's any difference. If you're constantly using and recharging more than 2 or 3 times a day, then it's most likely the battery.
Edit:
Quoted the wrong post.
You need to use aboot from V5.How long should I let it sit on the LG Logo before getting worried?
Alright, thanks man.As long as it has aboot.img, it doesn't matter what it is
can u pm me a link for kk f3 like to check it out as betaThere's just a couple things broken in kitkat that needs fixing.
