nobreak1970
How is it truly looking for us to get a custom (non-stock based) rom? No sugar coating please.
You devs are awesome btw.
You devs are awesome btw.![]()
I see that the metro pcs Optimus F3 has a custom rom for their phone couldnt that one be changed for the Virgin mobile Lg Optimus F3?
This may be what some of you are looking for:
http://androidforums.com/metropcs-t...ms659-p659-xperion-rom-updated-9-20-14-a.html
Note that the ROM author doesn't own an F3.
The Xposed AOSP Lock screen module let me put that on it. Only thing I don't have is the CM apps, nor do I have the Qslides app deactivated. XGELS lets you change the Google Now dock to Android L style without messing with the build.prop file.
I basically did this to my stock v7, same look without the Xperion meme.
I used Xposed framework with Gravity Box, and the paid version of Xposed XGELS.
I bet it's pretty much the same rom now. I debloated the phone using NoBloat Free. The XGELS module, paid version lets you theme the GEL, aka the Google Now Launcher with any Nova/APEX theme icons.The Xposed AOSP Lock screen module let me put that on it. Only thing I don't have is the CM apps, nor do I have the Qslides app deactivated. XGELS lets you change the Google Now dock to Android L style without messing with the build.prop file.
Added our Overclock V4 kernel and this thing is smoking. Gravity Box let me activate the Soft Keys/Nav Bar. Button Remapper let me reassign my capacitive back/menu buttons to other things. One of the modules, can't remember witch, let me change the action of the home button too.![]()
UPDATE: I just changed my status bar icons to kitkat style white, and also can change the color of the status bar itself.
Pimped out.
Sooo, I have a rooted, Virgin Mobile v7 F3, can I install xposed? ie this version: [APP][JB][XPOSED] GravityBox v3.4.2 - tweak … | Xposed General | XDA Forums
Cool, it works! Thanks for the suggestion! I would love to see a full-fledged custom ROM at some point though.
Awesome. I can test anything you would like.I'm not making any guarantees but I'm working on a build of CM-10. Haven't gotten a test zip built yet but I should in a few days. It probably won't boot though.
On second thought, it seems my status bar always changes its color back after I change it. I rebooted and everything but it will switch the color and then after I turn the screen off and back on its often back to the original color. Any thoughts on why that might be?Glad to see it worked out! Eventually there might be a ROM, only time will tell
