I realize now that when I installed the Windows 10 Tech Preview, it masked my Linux partition so I cant even begin to work on anything Android related.
Insert an ubuntu install CD and ubuntu will see both partitions.
Run the following commands in terminal:
apt-get install Boot-Repair (Name might be different but that is the application you need)
then run boot repair and click "Recommended Repair" in the main screen.
That should solve the problem.
Think my issue may be a bit more severe to fix. My GRUB is fine and I can boot into Mint or Tech preview.
Looks like whatever I did I was a full in-place upgrade. May have to start my Win7 partition from scratch.
Well CyanogenMod ROM is built with Ubuntu. I also know that Google recommends Ubuntu as well. So my best guess is Ubuntu.I have 4 partitions, Windows 8, 8.1, Ubuntu, and Windows 10, they are all still there, I just cant get to them. Going to try the method mentioned above.
What would you guys say is the best linux distro for andoid work?
We have the ability to jump back in software versions. The only issue I see is removing the update notification. Unfortunately some time in the not so distant future we may only have this option left.![]()
cguru:We have the ability to jump back in software versions. The only issue I see is removing the update notification. Unfortunately some time in the not so distant future we may only have this option left.![]()
