Root [Virgin Mobile/Sprint] Easy Way To Theme The LG System UI
This Is An Easy Way To Theme The LG SystemUI.
Here's What I Did On My LG F3
[/URL][/IMG]
[/URL][/IMG]
First you have to download Xposed Installer:Xposed Installer | Xposed Module Repository
Then you download this to theme the SystemUI: SYSTEMUI ICONS | Xposed Module Repository
Then You Open The App And Press The Plus Button (+)
Press System UI, Just Wait Till It Loads
After That Just Choose An Image That You Want To Change
When You're Completely Done, Reboot And It Will Seem That It Didn't Apply The Images And A Little Bit After That It Will Seem Like If Your System Ui Doesn't Work For A Minute Because It's Applying The Images
Then They tWerk!
This Works for most phones with root
But Not The T-Mobile F3
Take some screenshots when your done and put them in the description :P
By The Way I Didn't Make This, I'm Just Sharing It So More People Know
That It Exists.
You're Supposed to Get PNG Files To Replace The Current Ones.
But if it doesn't Work Then IDK :(
Yes. I ticked on plus + and Saved all icons
With Xposed, ticked on Modules and choosed systemui icons.
Saved and rebooted
Waited for 10 mins but nothing change :(
Sorry about my bad English
Saved and rebooted
I will put in the description that it doesn't work with the T-Mobile F3.
Sorry :(
Exactly what I want to do...suggest an icon pack perhaps? :)
Was already fiddling with that program as you posted your reply. :)
might one share a compatible custom UI with us??? hmmm? :)
I found an LG home Android L theme for LG (official theme) and it would look sweet with a modded status bar icon thing.
I love it now. Kitkat look.
I use Gravitybox to get the time white...rest is modded with Resflux.
