Rob22445566
Member
After doing a MEID phone swap, I'm now getting occasional Error Code 67 popup messages.
I have a rooted VM Optimus F3. It works fine with Wifi Hotspot tethering and I want to keep it that way.
How can I permanently BLOCK these messages (without doing a PRL Update)?
Any help?
Thanks.
Rob
(Solved) Here's the fix: Using the app System Tuner, under Apps Manager find GOOGLE SERVICES FRAMEWORK, then find CONNECTIVITY_CHANGE and uncheck it.
Now reboot and Error Code 67 is GONE!
Any help?
Thanks.
Rob
