daffyducknj
After watching SVU on TV last night I decided to pull out my F3 after several months of no use. (This is the same one that I thought was a goner after a bad spell of overheating.) I managed to boot cwmt. Also managed to wipe it fully. Pulled a 32gb MicroSD card from my Kyocera Event and reformatted it in Ubuntu with two partitions (fat32-ext4). Downloaded the stock V8 zip and installed it onto the phone from MicroSD...
...will it boot!?!?
It did, yay!!! Too tired to do any screenshots now, maybe later today...
Mostly installed titanium, link2sd, gl2sd etc. ATM recharging f3 in offline mode with my old V adapter so phone doesn't overheat. Not sure if I'll use it again as the daily driver. Spoiled with the speed of the LG Tribute, fast lte etc. I think there is something about removing lg spyware that'll speed up the f3. Need to look into that. If things hold up after a few days, I might get a 64gb card for the phone. Tossed out the old one as that turned into a read only piece of toast after f3 overheated badly.
Should snooze now, later folks!
...will it boot!?!?
