macgoddess
I use Link2SD to link files to my external SD Card. I read that when an app is listed as "updated" it means that there are two copies of the apk--the original and the updated one--although I admit, I am unclear on whether the apk is an installer or the app itself... Anyway, in an effort to free up yet even more space, I decided to try the Integrate Update Into System, which I think is supposed to integrate the updated apk into the ROM--or something like that.
I used Titanium Backup to backup everything and then chose two apps to try it on--Hangouts and Maps. (I know TB has an integrate feature as well, but I used Link2SD's.) It said it was successful, and then I rebooted my phone. The first thing I noticed was that my Navigation icon was missing. Checking with TB, I discovered that Hangouts and Maps were no longer installed on my phone.
When I attempt to restore Maps with TB, it just hangs and never restores so I have to kill the task. I haven't tried restoring Hangouts. So, then I tried reinstalling Maps from the Play Store, and it says that there is insufficient storage space to install. How can there not be enough space? There was enough space to have Maps and Hangouts installed in the first place.
Sigh...When I was checking things out with ES File Explorer, it looks like Maps is still there in system/app, so what gives? I don't know why Link2SD uninstalled the apps (or did it really?). I don't care about Hangouts, but I would like to have Maps back. Any thoughts or suggestions would be great. Thank you.
