Root [Virgin Mobile/Sprint] ls720zv8 lost root while v7 rooted fine, info needed
kaylsey
Edit: Need root for ls720zv8
Did a factory reset
Stump root, towel root, xmodgame root all no success *.*
C recent post below.
<3 Kaylsey
Hello forum,
I have searched and found some info but not veey clear info for what i need to do. I jave serveral lgOf3s. I allowed the v8 update on two of them and now root has been lost and programs such as towelroot and xmod rooting will not work.
- i am inquiring for info on how to roll back to v7.
I have found app to block the swsyem swoftware update to stop(disable services) in pay store. But first need to downgrade back to v7.
Any and all help will me much appreceiated xd
*K*<3
Hello forum,
*K*<3
Discussed in VM portion of forum. Thread Comments on rooting etc.
Thank for the steriotypical know it all answer. As i said above i check this foruma and lgf3 pages and couldnt get a clear walkthrew for rolling back to v7 from 8. Bit thanks for tryn
Side note. Has any one every jad a probelm w towel root as far as secrity? A while ago when it was workingmy phone informed me about the app attemting to access some securities. I forget the exact warning message. Butwanted to see if any one can say this is an unsafe or safe app.
The only thing you can do at this point is use the Unbrick Guide to flash the zv7 firmware. It provides a step-by-step guide to setting up and using the LG Flash Tool (LGFT). Without root and a nandroid backup there is no other way to rollback a firmware version. As far as Towel root goes, I have not heard anything bad. If you prefer to use something else though, Stump will root zv7 too.
I uninstalled the app after rooting. No need to keep it installed. I have it on my SDcard just incase I need to install it and root again.
Yes i did end up doing that and noticing that i remained rooted. But then that was all before this terrible.mess.
This title must have good keybwords it popped up first item in google while i was searching for methods to root v8. Xd
Guys im so stuck, atm im trying to go w the flowand run v8. Using my other phones that still have v7 are a pain. I am rooted but unable to get rit of the auto system update pop upthat kickes me off tasks. So making the phone for.gaming isless.
My objective is to find a way to root v8 . I did a factory reset and tried stump root.
No sucess w stump root ( even w it saying device rooted).....
Please can some one help me. Im by no means a programer/ super smart w this stuff. I jist want to be able to root my.phone again.
Any info for rooting my phone as it is.now would be so much appreceated. Youtube videos are awsome as well. I find trying to rrad these diys w all there abrevations very jard to follow.
As always <3 Kaylsey
try root master
