Root [Virgin Mobile/Sprint] [Resolved]Problem: Folders/Files recreating themselves?!
emkeene
Hello all!
I ran into an unusual... let's say quirk yesterday on my F3. I plugged my phone into my computer and set it to Media sync mode to move some downloaded pictures from /sdcard/Download onto my pc's hard drive. I cut and pasted the 100 some files where I wanted them to be, at least I thought so. I made a mistake so I hit cancel on the Windows dialog box after it moved about 50 of them. I pasted them again in the spot I wanted this time, and it moved them to my pc's hard drive as expected. Now here's where it gets weird...
I noticed that 49 of the pictures still have entries as an album in my gallery app. But instead of the proper thumbnails, it shows a cracked picture frame icon for all of them. So I open up ES File Explorer and there is 49 .jpg files inside my Download folder, all with a size of zero bytes. I delete them from my Download folder again. Weird, I thought but oh well. they're gone now. However, the next time I open my gallery app, they are back! All 49 blank, 0 byte .jpg files. So I hooked my phone back up to my pc and used Windows Explorer to delete them this time. But they keep coming back! So far I have repeatedly tried these methods as well as deleting them through adb shell, but to no avail. I have uninstalled and reinstalled ES File Explorer. I have tried a different file manager app (Astro). I have deleted the gallery3d folder in /sdcard/Android/data. I deleted the entire Downloads folder (it recreates that too). I have even cleared the cache and data for both the gallery and media storage apps. Those 49 files keep regenerating themselves as empty 0 byte files. No other files or folders on either the internal storage or external sd card are affected. I've even done a factory reset/data wipe/cache wipe/dalvik wipe/Rom reflash but they still come back.
Edit: I tried this app called File Shredder on the problem files and it worked. They are finally gone :-)
It sounds like one of your apps has a link to those 49 pics. The icon represents a broken link. Things like Google Plus, Facebook, Photobucket and other cloud services or just some type of photo app that you might have installed. If this is the case you'll have to figure out which it is. Then try to change a setting in the app to brake the link. My first guess is something Google or Facebook but that's just a place to start. Hope that helps.
