Root [Virgin Mobile/Sprint] [Rom] [ALPHA] [4.1.2] Cyanogenmod 10.0 Unofficial
Do you like puppy's?
  • Total voters
    4
  • Poll closed .
I use sandix's mount swap app to use my micro SD. I don't need to use both storages simultaneously anyway, thanks sandix for the app. For the keyboard I just uninstalled the one in the ROM and kept the one installed by the gapps package I have.
images
CyanogenMod 10 for the LG F3 Alpha release
Virgin Moble only at the moment.
CyanogenMod is a free, community built, after market firmware distribution of Android 4.1.2 (Jellybean), which is designed to increase performance and reliability over stock Android for your device.
Code:
#include
* Your warranty is now void. *
* We are not responsible for bricked devices, dead SD cards,
* thermonuclear war, or you getting fired because the alarm app failed. Please
* do some research if you have any concerns about features included in this ROM
* before flashing it! YOU are choosing to make these modifications, and if
* you point the finger at me for messing up your device, I will laugh at you.
All the source code for CyanogenMod is available in the CyanogenMod Github repo. And if you would like to contribute to CyanogenMod, please visit Gerrit Code Review
Currently, there is no device tree source available for this rom. It has not been created. It will be created sometime in the future.
Video of Cyanogenmod 10 running on the f3 (thanks sandix)
Instructions:
First time flashing CyanogenMod 10 on your device, or coming from another ROM?
  1. Root the device and install ClockworkMod or TWRP Recovery.
  2. Perform a backup of your current ROM.
  3. Perform a factory reset while in recovery
  4. Flash CyanogenMod.
  5. Flash GAPPS
Do not use bug tracker on Unofficial builds
What works but may need bug fixing
Calls/Sms
Audio/Sound
Wifi
Offline charging
Touchscreen
Brightness
Microphone
Data/3g
What's not working:
Speaker phone
Camera/Light
Headset/headphones
Data-4g
External SD
Proximity sensor
MTP
GPS
Tethering
Bluetooth
Home button led light blinks
To enable 3g:
You will need to go into:
Settings > More > Mobile Networks > Network Mode
Select: LTE/CDMA
Reboot the phone.
Download Links
ROM ALPHA 3
md5sum
f9bca1da3406858698bed70ccf723041 cm-10-20141124-UNOFFICIAL-fx3.zip
Click show to see changes in Alpha
3g data now works :D
keyboard fix
GAPPS
Google Apps - CyanogenMod
old builds
Alpha 2
Phone now works :D
Alpha 1:
Initial release - Sound & Wifi Only
If I have helped you, and you like my work, please click on the Thanks Button and give my thread a rating by clicking on the stars above.
If you would like to contribute to my hooker fund, you can click on the PayPal button
- xclusive36
- sandix
Note: I wanted to say thank you to cesarasm. Thank you :) You nuked your phone bringing this to our attention.
Will this work with V7?
images
Code:
#include
Instructions:
  5. Flash GAPPS
Calls/Sms
Audio/Sound
Wifi
Offline charging
Touchscreen
Brightness
Microphone
Data/3g
What's not working:
Speaker phone
Camera/Light
Headset/headphones
Data-4g
External SD
Proximity sensor
MTP
GPS
Tethering
Bluetooth
To enable 3g:
Select: LTE/CDMA
Reboot the phone.
Download Links
ROM ALPHA 3
md5sum
keyboard fix
GAPPS
old builds
Alpha 2
Phone now works :D
Alpha 1:
- xclusive36
- sandix
Hey xclusive, I am having trouble installing using the instructions you provided. Before I did anything I reflashed stock with the Lgflashtool. I rooted, installed Clockworkmod touch, flashed Cyanogenmod zip, then Google apps. But when I rebooted, it hung on the LG screen (The one before the boot animation begins.) Could you possibly tell me what is causing this? Thanks!
Did you Factory reset? If you are using TWRP, I've noticed sometimes it doesn't wipe everything. Go to:
Wipe > Advanced Wipe > select: Dalvik Cache, System, Data, Cache and Swipe to Wipe.
If you are using CWM Touch go to:
Mount and wipe System, Data, and Cache.
Then flash rom and gapps and boot :)
I noticed that in the last update that although GPS is still not working, it is finally pulling location data from WiFi and mobile network. This was something that was not functioning at all in the past.
I wanted to give you all a little heads up on my progress. Over the past week, I haven't made any. Work's been a little crazy lately. I've attempted to finish porting the rom over from the Korean version to US in an attempt to get GPS working. The only progress I've made was shrinking the rom size down. I lost WiFi. Basically a step backwards. GPS still doesn't work correcty. I won't be posting it for obvious reasons. :P
I need to take a hard look at what i'm working with and figure the correct next steps. Sandix, you've been great. You've helped me debug and help push me to the next step. I hope you stick around.
Would anyone be able to test for me? Sandix no longer has a active f3. I'm looking to be able to test to see if 4g works for a new update.
