Root [Virgin Mobile/Sprint] [ROM] [Stock-4.1.2] Solar ROM
Does the Google camera on this have a problem focusing? I know when I downloaded other nexus camera apps the shots appeared to be blurry compared to stock camera app. I use the camera a lot so I need to know before I make the jump.
Nice work btw. Can't wait to try it
Thanks! And as far as I can tell, the camera works well. Here's a sample picture in low light for reference
Probably, I went back and redid the link just in case. Thanks for letting me know though, hope you like it :) side note, to get to the custom font, you have to go to display, fonts and click roboto
Had a bit of an issue installing this (apps kept crashing), so I'm currently on that prerooted stock ROM. Somehow I have an extra 300MB free that I didn't before...
If apps keep crashing, titanium backup everything, wipe and reflash the rom. Then restore one by one. I know, tedious, but that's the only fix i can think of
so I just tried to flash this and It said Installation aborted and it shows the poor android dude with his tummy open and a red triangle.....heeellllpppppp
WAIIITTTT sorry I'm stupid sometimes. I had the new system update, do I need to re-flash to the old version, root, NOT INSTALL THE UPDATE, then this? I'm still new thanks peopleeee
Yeah, you need to be on the old version of the software to install this, so do exactly that. As for dirty/clean flashing, I've only done dirty flashes so far and not had an issue, while others clean flash. It's really up to you in the choice of the matter
I dirty flashed it and Play store FC'd on me :[
I also clean flashed and it did it again :[ I love this rom but thats my only problem
EDIT: I googled a play store APK and I downloaded and installed and it fixed the problem
I have no idea as to why play store crashes on you. I even reflashed to test it for you, and it didn't fc. As for after clicking roboto, you just click accept, and it'll apply itself. It's not drastically different, but i like the style of it. It's called Ubuntu.
Huh, i reflashed the rom and it still did it. idk. And the font is quite cool. I thought you meant like maybe we can use custom fonts of our choice.
Hmm. Alright, I'll replace Google Play Store again in the next update. Thanks latenight and redhead for letting me know! Also, I noticed that superuser had stopped working for me, so I'll be replacing that in the next update as well. Has anyone else had that issue?
