I see that on the Android Tuner app for F3 it shows CPU 1 online and CPU 2 offline why is that? Cant we open both cores on our phone?
Ty is that the last setting at the end i think it says md or mp? Should i not mess with it? Reason im asking is someone on the Zte Awe forum has a video on You tube where he shows the overclocking of both cores on that phone and shows CPU 2 where you can tap free and it opens that core up. He may have been on Android Tuner Pro he mentions trickmodester and different CPU settings
do i do that in mp? or where do i do that? I use performance. Would that be in root browser? UPDATE ok got that what would you say is a good setting i have 364/1188 on performance? Both cores open on Quandrant 5232 and Antutu 12509
You're gonna get the worst battery life ever and it will quickly ruin your processor and your battery if you use performance all the time and enable the second core all the time. Watch how hot your phone will get.
Not really true with modern processors. They have C states (idle states), so even though the frequency is locked at the max, the processor still goes to sleep when it has nothing to do.
In my testing for the new OC kernel I am about to post shows that even with the cores on all the time, with on demand, and the schedule MC scheduler, the phone uses almost no battery when idle. It is less resource intensive than turning the cores on and off.
