Root [Virgin Mobile] TrevE Mod wifi hotspot-Booting strangers?
Startech
I am software challenged. I rooted my phone, installed TrevE Mod after reading for a few days all of the help on this forum; and another forum....Thank You! Now I have a stranger connecting to my hotspot and I can not figure out how to boot them off and prevent them from jumping on again. I thought I read somewhere that securing the hotspot causes problems. Please help and type slowly to this newb....
TIA!
I used to get constant disconnects feeling with root but I've noticed that one I unticked driver reload it never happened again
When someone connects it should show a notification on notification bar that you click on which should prompt you to approve or deny.
I noticed that and the only thing I can do is put a check by them or uncheck them. So I guess if there is no check, they can be connected to the wifi hotspot, but without internet access?
Under menu I only have 2 options
Renew client list
Apply settings
