Well I'm pretty sure moon included busybox in conquest. If apps are successfully linking its probably the swap that's not working.
You can reflash it. Just make sure its the right file. Try looking in system/etc/init.d, see if you have the 11int2extsd script file. That's where the swap magic comes from.
Pretty sure I flashed room to roam.
I'll redownload it.
Delete the 11link2sd. Keep the 11extsd2internalsd. Might solve your problem.
. Thanks for trying to help though.Well you have to be rooted with superuser or SuperSU installed. Also this guide is for the Samsung galaxy victory and won't work on other phones. Especially don't flash any of the files, the mount points are specifically for this phone. Some phones don't even use ext4. You really should find a guide for your phone. But as long as you don't flash the swap files this MAY work for your phone, but I wouldn't risk it. Su error sounds like you're not rooted?Hey i need help. this is the first time im doing this sort of thing so i have some newbie questions. My phone is an alcatel one touch. I followed the steps up until i reinsert my sd card and boot up my phone. i opened up link2sd and chose ext4 and it gave me an error saying that mount script couldnt be created because of the su. how do i fix this? any help would be appreciated thank you!
ah i see. thank you for answering i am just going to format my sd card and reset my phone back to normal. cheersWell you have to be rooted with superuser or SuperSU installed. Also this guide is for the Samsung galaxy victory and won't work on other phones. Especially don't flash any of the files, the mount points are specifically for this phone. Some phones don't even use ext4.
