Root [Virgin Mobile] [Vmobi][ROM][ALPHA] CyanogenMod Jelly Bean 4.1.2 [08.25.2013]
Just did it and it was successful! I'll try to post the files if anyone wants to compile a zip.
EDIT:just found it, anyone know how and where I would be able to post from root browser in rom toolbox?
Just uninstalled 0.2 and installed Trebuchet 1.0, ported from CM10.1 4.2.1 to CM10 by krazzyvishal . Has a few cool new features like transition effects, hiding icons, etc. There are like three options that if you try and choose it'll crash but you can go right back to it. Won't even notice it crashed. Can get the file from here - http://forum.xda-developers.com/showthread.php?t=2107705 Honestly... I don't even know how I installed this. Installed nova so it took default launcher, then forced closed trebuchet, cleared its data, deleted it in system/apps and copied the new file over, then changed permissions to rw--r--r. Then rebooted and uninstalled nova.
P.S, screenshot is volume down plus power button
I tried to flash it and no I did not wipe everything before I flashed it. I followed that one guys instructions to flash it and I only got to the boot screen
Just tried to flash it again and I really like all of it. I've found a couple of things that aren't working that are probably well known by now. Another odd thing that before I flashed this ROM I had at least a three bar signal strength in my room now it seems to stay at 2
I believe that the scaling is different. Cm has 4 bars max and stock has, I think, 6 max.
So I can't seem to send long messages I sent about a 4 message long text and it didn't work. Also I'm trying to download a MMS message and it does t seem to work
3 days ago I switched to my victory full time, using 3g instead of WiFi through the old Opti. Not one random reboot.
Unrelated note: still waffling on whether to give that glorious piece of hardware a viking funeral.
From my experience you should make a full backup, then what I do is wipe data and install then reboot. I was at first doing a list on unnecessary things... Lol
