Root Virtuous 2.7 vs Virtuous 3.0.1
rsarno
Thank Me, Im Irish!
Can anyone detail the differences between these? Im on 2.7 now, what will i notice that is different?
Also im not sure what the difference is between the kernals offered as well. There is stock, and custom. Is there also a kernal optimized for battery? or is that built into one of the others?
Thanks all
i dont see much difference, am i missing something?
and i thought there was a battery optimized option? thought i read that somewhere
Thanks all
There's really not much different that would affect anything. The kernel's are the exact same. Same stock kernel or same custom kernel. He's just reversed some of the app relocating he had done, but added a very nice app that is based on gscript that allows you to customize some of the stuff on your own. He's also cooked in some of the already available versions of certain apps.
