jonathang94
Hi, sorry if this seems very noob-ish but I'm having some trouble with getting Virtuous inquisition v 4.02 to work. Basically it loads up but gets stuck at the V boot logo.
1) I rooted the phone using the HTCdev unlock method and installed Clockwork mod recovery.
2) I didn't install the firmware
3) I copied the ROM over to the Sd card root and flashed it with CWM
And now it won't work. I've tried to apply the firmware update since then but whenever I put it on the Sd card and try to update it I get a notice saying "No image or wrong image" for several different things.
Thanks for the help in advance. I've been spending hours trying to fix this!
