Root VISIONary+ Issues? READ THIS
SB13X
Android Expert
Used Visionary to Root my DHD yesterday and as its the first root I'd done as I imagine a lot of users of it will be. Now for those worried about bricking their device having not tinkered with the other options following some website guides just tapping temproot then attempt permroot you may find it fails to work.
Now for those mentioned who might give up here don't all you need to do to successfully root is to tick the Run visionary.sh after root.
HTH someone else.
HTH someone else.
This still doesn't work ??? anyone have any other ideas ? and yes I am running version visionary+ r14 and my firmware is 1.32.405.6 .... Desire HD
this is sending me mad :mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad:
I know it sounds stupid but you are ticking the box and then continuing to do the temp followed by perm root?Other than that all I can think of is if you put all your software profile up so I can compare to mine.Is yours an unbranded handset? If not might be with debranding it with a goldcard first?
I tried to install visionary+ r14 it says that it is successful but I don't get the Superuser application, any ideas?
Dunno if I made the OP clear enough but the Run Visionary.sh should be ticked prior to clicking temproot and should be left selected when pressing attempt permroot.
