I have gotten it on my Zte Grand Maxx+
That's why, I want to see if anyone on Marshmallow has received this update.Kit Kat still
Never used it, but can't you just update it from the Play store? It's there for update in "My Apps" but I have no interest in it.
I'm thinking about switching to Cricket soon. I didn't know about this feature. Is there a charge for this? I didn't see one mentioned on the Cricket website.
Thank you. One more reason to make the switch.
The new version has a nicer look to it (IMO), but the options available in settings are extremely limited. Has anyone found a way to change the notification sound or disable vibration?
The default is to use the earpiece. They just changed the icons to a speaker (representing the earpiece) and a speaker with some curves next to it (representing the speaker).So far there is no setting to change notification, disable vibration, not have the voicemail heard over speaker by default.
That's true - you can't change the default from earpiece to speaker, but you said (emphasis mine):Yes we know that, but we cannot change the default earpiece to be default speaker. That's what we are saying.
Which indicates that hearing voicemail over the speaker is the default, which it isn't. It seems I misunderstood what you were trying to say.
