N
naelocin
Guest
I'm using Verizon's Visual Voicemail and twice it has wiped my entire inbox. Luckily I had saved the important messages, so there was no loss, but that won't always be the case. Has anyone else had the same problem and found a fix?
And I know that everyone says Google Voice is better, but I'd like to find a fix to the problem since I'm using Visual Voicemail right now.
