Root Visual Voicemail on Froyo?
DougFunny
Member
Im currently running EVOlution V8 RevA on my evo and ive been wondering if I can use visual voicemail while running this rom?
Yes. I was running this yesterday and today too to try it out. You need the Visual Voicemail apk on your SD card and just install from there. If you open up the zip to either the stock ROM or a different ROM like Fresh or BuglessBeast you can find it in there, too.
Check out youmail.com
They have a free app in the market place also. Once you try it you'll never look back and the best thing is if you change carriers you just relink your phone and you're good to go.
