visual voicemail with bluetooth
cybric
Just like with my Moment I can't get my visual voicemail to work with my bluetooth earpiece. Is there a way to fix this? Thanks
You need to get a bluetooth earpiece that can support A2DP profile. Otherwise, it won't work at all due to current Android limitation. The Android Froyo 2.2 may have the fix.
