Visual Voicemail
AlexKP
Member
I just downloaded YouMail from the marketplace and set it up but wasn't sure if that was my best option for visual voicemail. What can you guys suggest or what are you guys using currently for your visual voicemail needs?
google voice is the best, i was on verizon visual voicemail, and didnt want to leave it, til i got the google voice working properly with my voicemail greeting modified. now i wont change it.
