Root Vitria Info
just noticed a problem, when you underclock the vitria with setcpu or something you will momentarily control the 2nd core but once the first core gets loaded the 2nd one will go to its max frequency(even if you set it lower) its really annoying, I can see it especially in quadrant.
Where is the original bootanimation file stored?
I got tired of the metropcs bootanimation so I made a new one, its pretty much the google now animation but instead of google it says huawei(in huawei's font), and a bootanimaitonex(the fast boot bootanimation) that only says huawei. If anyone wants it let me know.
you don't need to use adb, just make sure you have root and use something like xplore or another root filemanager and copy and paste the bootanimation
if you still want to use adb remember to mount with rw permissions so
mount -o remount,rw /cust
then use chmod on the folder you want to push to
Worked well. Thank you!
When I go into bootloader or at least try to get in, I just get a screen that says
"Bootloader Lock State: LOCKED"
and it doesn't allow me to use adb or anything extra than that, I'm kinda stuck at this part until I figure out how to get past it.
Any help?
what are you trying to do?
You can't use any adb commands in fastboot, you use fastboot commands in fastboot, and you still need to unlock to use fastboot otherwise it denies.
When I do adb devices it doesn't get recognized at all and says its not even there.
I have hiSuite installed and all the drivers but it doesn't let me do any fastboot things nor does it change anything.
It just says "Boot loader Status:Locked"
Hey,, can i ask question about g526,? My phone doesnt boot normal.. bootloop and it taking 1 hour and same with the recovery 1 hour before the menu shows.. its original rom was g526-L11.. but i flash it L22 rom.. it has cwm v6.0.3.7.. i tried to flash cwm recovery with stock recovery through fastboot.. i had its bootloader unlock.. but when i go to recovery the cwm is not overwritten.. do i need to root this phone? If it is? How to root it through recovery using adb command
one more question.
when I tried to move the apps from phone to sd card, it only moved the apps from phone to the internal SD card which is only 1GB.
Is there any way to move the apps to the external SD card?
I tried a few apps like link2sd but none of them worked.
