VK ICS V5.1.2 + Lock
shenga
After having tried various roms over the last 6 weeks or so, I found this one and I have to say I love it. Had been waiting on the new Checkrom but Im definitely gonna stay with this one for a while.
After installing the rom, I installed VK--Add Lock in status bar.zip which I realised after I didnt need to do. Question is, how do I get rid of it and the "Lock" back to where it was before, which was just below the status bar ?
I'm not sure if just copying the /system/app/SystemUI.apk file "hot" from the ROM zip directly into /system/app on your device will work, as SystemUI is always resident, there may be a permission issue. You can certainly try. You would need to give it rw-r--r-- permissions.
If this doesnt work you would need to create a CWM flashable zip file to do it
Thanks for that Hawker.
A straight "hot" copy didn't work so I ended up just flashing the rom again using a no wipe.
Everything appears to be back to normal.
BTW - I installed this rom due to one of your earlier posts. Absolutely love it. Tried most of popular roms going around but I prefer this one even to the old V6 checkrom. I was having a problems adjusting to ICS but due to this rom, I think I'm now there.
Thanks for the heads up.
