VM down or my Triumph??
TekOne
Member
I'm in Los Angeles area and last two days my Triumph having bad signal with no bar... my 3g 23-45kb/s on each test. Usaully, i get 3 bar or 3g 445-650kb/s I don't know if it my VM down area zip code 91XXX or Triumph? I call VM and gave them my zip code, they claim they're fixing the problem.. let me know if anyone having similar problem??
Mine is 917xx almost similar than yours and works fine, been all around from, Claremont, Pomona to Santa Monica and all fine, a little low because of the heat, but working fine, maybe it's the tower near you...
NO, it always has 2-3 bar.. and 3g signal at lease 200kb/s with g60madman 3g fix. Hope it will fix with less heat.
