Root VM issue with ASOP oICSv26 Rom
JMac202
I had a missed call. Went to VM like all the others. Well now I can't check it. I dial *2 and says invalid code. Dial *86 like it says on screen the same thing. The biggest annoyance is I have a VM notification I can't even clear.
Anyone know how I can remedy this?
I have the same ROM and tested this and I have the same problem. The only way for me to check my VM from my phone was to dial my own number. That also cleared the VM notification. Love the ROM I'm not to worried about this problem. Today the new Galaxy comes out with Andriod 4.0. We will start seeing more stable ROMS with 4G radio very very soon. :)
All you have to do is go to settings, call settings and find your voicemail settings. Once you do, select it, then select voicemail number and replace the *86 with you phone number. Once that's done, you'll be able to hold down the 1 key in the dialer and go to your voicemail.
I looked for call settings but cant find it. Can't find anything for Vm either.
I'll I have is sound, display, storage, battery, apps. accounts & csync, Location services, Security, Language & Input, Backup & Reset, Date& Time, Accessibility, Dev Options and about phone.
I'm so dumb. I was giving instructions for cyanogenmod. To access vm settings on this rom, go to you're dialer, hit the menu hard key, select settings and it'll take you to the call settings menu and the voicemail number setting is the 3rd option in the list.
