TryingToRoot
When I had the Prevail we started playing with Vocoder settings within the phone and ended up getting some positive results. So once I gained my msl by using the method |MONSTER| had posted, I decided to try. The results were stunning, my 3g speeds are now averaging 1mbps down and 670 kbps up.
First, apply Experimental 2 settings from the 3g turbo scripts I posted in an earlier thread.
Then, in your phones dial pad dial ##3282#
Tap Advanced then edit
Enter your MSL
Then Change the following settings in the picture below
Change the three vocoders to 4gv
and enable EVRC_B That is all.
Hit home button and phone will reboot
Explanation of EVRC and 4gv here:
http://en.m.wikipedia.org/wiki/Enhanced_Variable_Rate_Codec_B
Disclaimer:
This is an experiment that worked for me. There is a chance that you could mess up your settings, so you do so at your own risk.
Enter your MSL
Disclaimer:
