born_fisherman
Member
So I'm on my #3 Captivate now.. and I need to get some other people's experience on these items.
First off, my #1 Captivate would get hot while on voicecall (lets say 15min), the #2 phone would NOT get hot even after a 30min call. The #2 phone also had the longest lasting battery of the 3 as well. But the phone could not see ANY satellites so back it went..
#3 phone - I'm not having the best experience with - I downloaded the BatStat widget to monitor temp and battery percentage.. So I dialed my wife's phone with the battery at 35%, and temp at 36 degrees-
8 minutes in - 40 degrees and 30%
11 minutes in - 42 degrees and 28%
14 minutes in - 44 degrees and 26% (getting uncomfortably hot on my ear at this point)
22 minutes in - 42 degrees and 24% (I put the phone on the table and the temp has dropped 2 degrees in 5 minutes. Is this an issue with the proximity sensor??)
Ended call at 11:54PM - in (1) minute, phone is down from 42 to 38 degrees
So since I've had the issue with the temperature before, I know it should not be happening - Does anyone know what causes the temp to go up so high?
Am I in the same boat as others with these two issues combined? I will most likely return the phone again tomorrow...
