.Nope, tryed it it comes up with please check network and try again??, i have 500mb a month, not a heavy user of web searches but dont like the thought of it connected all night while working!!It's easy to tell.
Long press the power button and de-activate Data network mode, then test it.
It didn't work on mine though.
PS Don't you have any data included in your plan? I use the net a fair bit and I've only used 200MB in two weeks so a few searches are not going to push you over the limit unless it's tiny.
cheers mate, am with vodafone will wait to see what i have used after the first month!!I never ever turn my phone off except when I'm flying and it's not caused any problems with data usage. The only time I turn the data connection off is when I'm working abroad, which happens fairly frequently but not for long periods.
I would be astonished if you get anywhere near 500GB unless you are downloading lots of music or large videos. Otherwise you'll struggle to use that much whether your phone is on all the time or not.
I'm on O2 in UK. If I just go to o2.co.uk (not using wifi) I don't even need to log in and I can check my remaining minutes and data allowance in a few seconds.
I don't think you have anything to worry about. Try it for a week and check, you'll see it's no big deal.
