Help Voice Dialing not working via bluetooth
BigDannyG
I just purchased a Huawei Ascend from MetroPCS and am unable to voice dial using a bluetooth headset. The voice dialing app doesn't trigger for some reason. Receiving calls works fine so the headset appears to be paired and connected OK. Anyone else having this problem or know of a solution? Is there any way to change or modify the headset profile?
What app do you use to get a dialler on BT? That's the feature I miss most from my pre-android phone. I've seen it on a US Cellular phone, but the app came from them. I can't find it on my Metro Ascend...
Mine's no longer stock, so maybe I removed it, but I only rooted and mod'd trying to get speed and BT voice dial.
With BT connected, it doesn't offer the voice dial option without having to go through the selection process on the screens. On my non-android Samsung, long hold on the activate key and it said "say a command", worked great. I saw a friend do the same on his US Celular Android phone (Samsung Galaxy class, don't recall the exact model). It was a US Cellular app, and it was running Android 2.1, same kernel as the Ascend. I thought it was something that was only on Froyo 2.2. and above, but obviously not.
I want that app, I will not dial or text while driving.
On stock, Even on Icarus I NEVER even got the voice dialer to work at all. With or without the bluetooth. I'd tried every darn thing I could think of, Nothing. -.- IDK.
