Help Voice Recorder not working
Skree
Hi Im a newbie and just got the Optimus M. I have downloaded a handful of apps but nothing too major. I have not rooted the phone or done anything like that, but I just tried to use the voice recorder to record some songs and it keeps saying "internal error". It does this for both modes, MMS and whatever.
Does anybody have a similar problem or any suggestions? :confused:
Also, how do you get these apps like Boingo and the Metropcs Wifi app to stop coming on? I get the memo widget and almost everyt app coming on automatically every few hours!
Thank you in advance for your time and help!
:eek:
With Froyo(Android 2.2) You don't need a Task Killer, that will just cause more problems, Froyo automatically runs app, it's part of it's task manager.
:eek:
Root the phone (temp or perm, your choice) and DELETE Boingo.
For the Easy Wi-Fi app, just disable the "Network notification" checkmark box (Settings/Wi-Fi Settings), if you don't want audible chimes and beeps every time you pass a free wi-fi hotspot. But don't delete the Easy Wi-Fi app -- it gives you free access to over 500,000 hotspots around the country. You might need one.
Hi there,
I work for Boingo Wireless and can give you info on disabling Boingo Wi-Fi notifications:
1) Select Boingo from applications group
2) Accept the EULA
3) While in the Boingo application; select the device’s menu button
4) Select settings
5) Uncheck both Auto Login and Hotspot Notification options
If you happen to need high-speed Internet access, give us a whirl and let us know what you think about the experience.
If you have additional questions about Boingo, feel free top email me: bnguyen@boingo.com.
Best,
Baochi Nguyen
