T toneclone Lurker Aug 27, 2010 #1 I have two version installed - 1.4.6 with an option to uninstall and version 1.6.0 with no option. the first one i installed from the market prior to updating to 2.2 android. All works ok. Am I ok to remove the earlier version or are the two working together? UK USER
R Raggy Member Aug 27, 2010 #2 toneclone said: I have two version installed - 1.4.6 with an option to uninstall and version 1.6.0 with no option. the first one i installed from the market prior to updating to 2.2 android. All works ok. Am I ok to remove the earlier version or are the two working together? UK USER Click to expand... The 1.6 version is installed as part of the 2.2 Android update, so yes I guess it's safe to uninstall the older version
S speedycolzalez Android Enthusiast Aug 27, 2010 #3 Odd... I'd installed voice search while on 2.1 (I don't know what version) but having upgraded to 2.2 I only have the provided version (1.6.0). I'd have thought you can uninstall the older one. However you do so at your own risk
T toneclone Lurker Aug 27, 2010 #4 ok I removed the earlier version without a problem leaving just 1.6.0
