Help Voice Search updated -problem
dibs ODDJOB
So Google released an updated Voice Search app.
Google Voice Search update helps you personalize your results, helps Google build another database to take over the world -- Engadget
Basically it adds personalization so it learns your own voice over time for better results. However, I have updated the app and I don't have the option in the settings to allow this. Anyone else run in to this problem? I am rooted and runnign SkyRaider 3.5, so I wonder if that has anythign to do with it.
It still works fine, and the accuracy was already pretty great, but I wanted to test out the new update.
The first time I opened it after the update it prompted me to choose whether or not to use Personalized Recognition. I also found the setting by going into the phone settings, voice input and output settings and choosing voice recognizer settings.
I had to wipe my device, install Voice Search,then reinstall my other apps with Titanium. I then accidentally updated Voice Search in the market, which screwed it up again. So I wiped again, and detached the app from the market. So far so good.
