Help Voice when receiving calls or texts.
When ever I get a text message or a new call my ringtone will start to play and then a womans voice will say the name of person calling or their number if not saved in my contacts list.
This is annoying the hell out of me trying to turn it off. I dont like people knowing who i am texting and would like to keep that private!
Can any 1 help me PLEASE! :confused:
Hello
Try this it 'may' help....go to your settings and you should see ' voice input and output' , its on page 140 of the online manual. De-activate the Driving Mode. On my Samsung Apollo, this is the option that I use to shut her up!!!
Regards
Miss Diva
Text-to-speech settings
●● Listen to an example: Listen to the spoken text for an
example. Install voice data for using the text-to-speech
feature.
●● Driving mode: Activate Driving mode to set the device to
read contents aloud. (***switch off this***)
●● Driving mode settings: Specify applications to use in
Driving mode.
●● Always use my settings: Set the device to use the settings
you specify in applications rather than the default settings.
●● Default engine: Set the speech synthesis engine to be
used for spoken text.
●● Install voice data: Download and install voice data for the
text-to-speech feature.
●● Speech rate: Select a speed for the text-to-speech feature.
●● Language: Select a language for the text-to-speech feature.
●● Engines: View the text-to-speech
