Help Voicemail Icon
I recieved a voicemail message yesterday and once i had listened to it and deleted it i hung up the phone as normal.....
The voicemail icon however will not extinguish from the top of the home screen......
i have rang my voicemail....Orange incidentally.....and there are no message to listen to
Have turned on/off phone a number of times....
when the phone boots up it shows voicemail and for me to dial my own number..........
H E L P....................
Have you tried dragging down the Notification bar (the bar at the top containing the voice mail icon, signal, battery indicator, time, etc), then pressing 'Clear', top right?
Two more things I can think of...
Menu > Settings > Call > Clear voicemail notification
Or a 'soft reset', Power off phone > Remove battery for 30 seconds > Replace and power on
