Help Voicemail number
Marvel901
Hi,
I was setting up my voice mail number on my SGS 2 and made a mistake, so that now pressing and holding 1 on the keypad dials a number that is incorrect. Does anyone know how to edit this please??
Cheers
You've probably sorted this by now, but I was looking for the answer too. Worked it out... applications/settings/call/voicemail/voice mail number.
Cheers
What number you call depends on what carrier you are using. Call you carrier and they will give you the number. This should be set up automatically when you insert your SIM card and the network recognizes your phone.
