1. Is there a way for the sprint voicemail to be just the normal/default computer voice similar to what I had w/ att...along the lines of "You have reached the voicemail of XXX-XXX-XXXX, leave a message after the tone" instead of having to record a greeting?
2. Whats the difference between the voicemail app and widget, if any?
Thanks
Thanks
