Help voicemail volume
Im sure this is a user issue, but when Im listinging to my voicemail, the volume gets really low. I have the incall valume all the way up, but for somereason I cant hear vm, any suggestions?
If you're using visual voice mail, which is actually using your data connection, yes the volume can be low, despite having the volume all the way up. I can only hear mine in a very quite room. If you need it to be louder, you'll have to push 1 on your phone, and connect via voice call. Which does by the way use up minutes.
My phone just developed this malady, and it sucks having to dial 1 for voicemail just so I can hear it at a louder volume. There has to be a way to get the volume back to normal on the voicemail stored on the phone.
