SMARTPHONEPC
How big of a deal is the 2.3Gingerbread's native support for SIP VoIP telephony?
What are you currently using?
I currently use Sipdroid on the EVO 4g and it works out great... sometimes, there is an echo, but calls always go through. Currently, Sipdroid will create your PBX account w/ a host and setup the linking between the SIP client on the phone and the PBX. In this config, calls are routed using Google voice.
While it was previously a hassle to work with (touch pro flashed w/ android overlay running sipdroid w/ no service, just wifi) that is not the case now. I would highly recommend using it if you need a SIP client and want a plug and play solution.
PS. Sipdroid works just like the google voice call options where if my wifi is enabled (Sipdroid auto enabled on wifi startup), then when I place a call, i have the option of using my normal #, google voice via mobile network, or sipdroid (google voice via wifi).
Also, there seems to be an option to use 3g or edge to make the call, although if you have a network signal, why you would want to use a SIP client, I dont know.
The GV method wouldn't have worked for me as I had no cellular reception at all where I was working. I needed a data-only solution.
I've got a stock 2.2 Evo, so I don't know what 2.3 offers, but you can use sipgate instead of sipsourcery with Google Voice. Sipgate (sipgate.com) allows free incoming calls. You configure your sip client to use your Sipgate account, and register that number with Google Voice. When people call your GV number, your sip client will ring. To make a call, you initiate the call with Google Voice and it will call your sipgate account first (ringing your sip client), then connect you with the party you're calling. I used this quite a bit from my PC until GV supported 'voice chat' directly. I still use it occasionally with my Android phone. This solution will become unnecessary if Google ever ports 'Voice Chat' to the Android phone. Until then, it's a very workable solution.
You do have to answer the SIP client call first. Once you answer, then GV initiates the call to the party you're trying to reach. It will not use plan minutes, because it isn't a phone call, but it will use data. If you are on an unlimited data plan, no sweat. If you are on a limited data plan, then you'll have to see how it affects you.
3) You can use Sipdroid over a telco network connection (sprint), but why would you if you get signal. I use this in places I don't get signal.
there isn't one. since it's using google voice, it's free.
Read the article I linked. Google voice doesnt call you back. IT MAKES THE CALL OVER WIFI.
