Help Voltage too high
hi guyz! I am knew to this forum. Ok i use a galaxy S2, recently after charging or during charging there is this irritating pop up warning message that says that charging is paused voltage too high! Also when i want to connect via USB it says the cable is connected while its not.
I have searched the net and i see couple of S2 users have this similar problem, also i have called samsung and they have suggested i take the phone to where i bought it.
Just wanna find out whats the problem and how do i fix it (if its a DIY)? or is a software related?
Thanx!
Welcome to AF Benedict117!
It sounds hardware related to me, have you tried another cable? Could be an issue with the charging port?
I've moved your post to the SGS2 section, folks who own the device will be in a better position to assist. :)
Hello
I have faced the same issue and found problem with the charger.i bought a new charger and is now working fine.
