needtooy347
Member
I download Volume plus it work great.
I don't understand the question. Not root? Why would that be a factor?What About you are not root
For true volume boost, you need to be rooted with superuser permission. That's why I only recommended a rooted app. Any noon root option you choose will just be an equalizer that will change the sound but not actual volumeI try many volume booster. None them work.
If you rooted,You can try this:
AC!D Audio Engine:http://chautemseric.wix.com/acidaudiotechnology
I got this downloaded. Didn't realize it's a zip. Does it need to be installed through recovery?
I've NEVER used a non rooted app that did what DSP manager or viper FX did for any phone I've used and I've tried many. If the technology exists then or now then wrong I am, but I've never had one workWrong, for true volume boost you need an amp. The highest volume you can artificially achieve without distortion is 0db.
Most likely, don't forget to back up your current system.
Im using viper Fx right now on my rooted Volt. Love it. And good luck flashing the Acid mod when we don't even have a working cwm yet
i am completely disgusted with this phone when listening to music in my truck it lacks bass and overall output volume to my system... BT and 3.5mm.... and headphones cant even go loud enough to drown out a lawn mower... this was my replacement to a 3rd gen ipod touch 32gb and its failing when it comes to audio playback
