Root Volume booster?
kidkrooks
is there a setting or a build.prop or know what to edit in mixer_path.xml I can boost my volume with. whenever I use visual voicemail my volume goes up to the level I would love it normally at. is there any way I can make that permanent?
Until we are able to get a custom recovery installed so you can make a nandroid backup, I wouldn't be messing with the build.prop.
Try Volume Ace Free from the PlayStore until then.
Do NOT mess with the mixer_path.xml, someone did so and ruined their phone's audio, but what I would do if you feel experimental is that you make a copy of that file and set it somewhere safe, then if audio breaks, you can easily copy the original back into place.
If you are rooted try viper4android. Awesome sound mod and plenty of volume boosting options.
I downloaded viper and i had no clue which one other than the one that had the 4.X version option to get and half the language in the store was an asian typefont so i have no idea if i had the right one or not.
It really didnt boost much at all and there isnt any explanation regarding all the settings, which are really cool but again no idea what they all do, im no audiophile per say.
