Volume button difficulties when using a case?
hal1
Android Expert
How is the volume button working out with your case?
I'm using the Verizon silicon case until my Seidio gets here. The silicon cases seem to be made so that there's extra material that pushes against the volume button, since the volume buttons seem to be flush with the phone. - not working out too well.
But what about cases where they have a cut out for the volume? Are you able still depress the button?
It isn't the friendliest volume rocker I've ever had, even the Tbolt was better. I use volume control, a simple great app.
I"ve got the Verizon gel type case and it is a pain. The volume rocker was hard to use initially now it is really almost unusable. I ended up going to the sound control (menu>settings>sound) and making all my volume settings there.
I use a fingernail to press up and down. Cruzerlite case with proper cutouts. The more use the better the TPC responds, a case of use it til it works. lol
Otterbox Defender series here and buttons work better with the case on than they do with it "nekkid".
