Help Volume control buttons
scarface_
Hey guys,
I love the incredible but I have one pet peeve and that's the volume control buttons. I always seem to press it by accident and go into vibrate mode.
Are there any other uses for this button besides camera zoom? Is there something more logical it can be mapped to? You can always have your volume control on the home screen, so I figure it's best to disable it alltogether or use it for something else. Any suggestions?
You can disable the buttons and use this "Volume Control Buttons Saver" app to control the volume by touch. Check out the app at http://www.wildroid.com or at Google Play https://play.google.com/store/apps/details?id=com.wildroid.volume.control.buttons
This app provides a way to access media sound system volume controls interface by "touch" rather than using the hardware device buttons. This app works on most Android Tablets and Phones. For quick and easy access to volume control, pin the app to the notification status bar. Then simply tap the speaker icon in the status bar to adjust the volume. The volume control will remain pinned to the status bar even after rebooting the device.
